FS: MTX Thunder 502 2Ch Amp!
Discussion in 'Car Audio Classifieds' started by RekD0514, Mar 15, 2007.
  1. RekD0514
    RekD0514 Full Member
    This amp has been sitting in my room for a long time collecting dust. I would like it gone for $125 + shipping or highest offer. It really hasn't been used much at all (maybe a year) and has been sitting over a year. It is in great condition with a lot of life left in it! Send me an email at rekd0514 at aim dot com. I also have the same name on AIM if you would like to send me an IM. Here are some references and my ebay account is rickytheracer on ebay. Send me an message on ebay if you would like to verify.
    References:
    DIYMA
    dwicker@gmail.com
    dawgdan aka Dan - ID12D4 v3
    tn_audiophile@yahoo.com
    Tn_audiophile aka Jeremy - Arc Audio 5150xxk
    ptricks@cablelynx.com
    skibum aka Todd - Alpine CDA 9815
    Sound Domain
    lasley1@hotmail.com
    FRITO aka Luke - Wiring
    Bring97@gmail.com
    REBring97 aka Austin - Diamond Audio D661s
    MJWillemsen@aol.com
    E36m aka Mark – Diamond Audio D661s – Sold
    Specifications
    RMS Power 12.5 VDC
    2 Ohm Load 180 w x 2
    4 Ohm Load 90 w x 2
    Bridged 4 Ohm Load 360 w
    Dynamic Power 14.4 VDC
    2 Ohm Load 250 w x 2
    4 Ohm Load 125 w x 2
    Bridged 4 Ohm Load 500 w
    Dimensions (with ISO Feet)
    12.6"x 9.75" x 2.1"
    32.1cm x 24.8cm x 5.3cm
    Input
    Low Level Input
    Crossover(s)
    Hi / low @ 40Hz-200Hz - Variable Defeatable
    Compression Circuitry
    Thunder EQ
    RCA Output
    Variable Hi, Low or Full Range
    Signal to Noise Ratio: ¡Ý110dB A-Weighted
    Damping Factor: >200
    Frequency Response: 20Hz-20kHz ¡À 0.25dB
    Maximum Input: 8Vrms
    Thunder EQ: Variable Bass Boost (0-18dB) centered at 40Hz
    Crossover: Variable 40Hz to 200Hz, 12dB/Octave Stereo
    High Pass, 24dB/Octave Mono Low Pass, or Full Range
    http://www.mtx.com/caraudio/archive/2004amps/thunder502.cfm
