FS Jensen Mono Block amp 650 watts
Discussion in 'Car Audio Classifieds' started by chance94z, Apr 15, 2007.
  1. chance94z
    chance94z Full Member
    JPA1300M
    Mono Amplifier
    Features:
    CEA Dynamic Power (all channels): 650 Watts
    CEA RMS Power Per Channel @ 4 ohm: 300 Watts x 1 400 watts RMS x 1 Channel at 2 ohms.
    Side mounted preamp controls
    Continuously variable crossover from 40 ~ 250Hz
    Continuously variable iX2-Bass, 0 ~ 18dB boost @ 45Hz
    Low level inputs 300mV ~ 8V
    High level inputs 2V ~ 10V
    Pass thru RCA outputs
    Unregulated MOSFET power supply
    SLAM circuitry
    Heavy duty die cast heat sink
    High current oversized power / ground terminals accepts 4-gauge wire directly
    High current speaker terminals accepts 10-gauge wire directly
    Output stage easily drives 2-ohm loads
    I had this amp powering 2 Kicker comp 12s and it was awesome. This amp is excellent working condition. Asking $65 shipped. Email me at chancehd@yahoo.com with any questions.
  2. aznboi3644
    give you 50 bucks for it
  3. Hautewheeler
    Hautewheeler Full Member
    yuk azn.. what are you gonna do with that? - start a fire?:D
  4. TheViking
    Hey, dont knock it...they can do an honest output that would make a great starter sytem for someone!!
  5. Hautewheeler
    I have seen so many fried jensens in my little lifetime.
    I feel I have license to knock.. they are a decent setup, but the components are just enough to do so for a little while, and then kapoo..
    sure.. you can buy one of those, and then save money for a brand new fire extinguisher. you can mount it next to your capacitors.:D
  6. aznboi3644
    I need an amp for the girlfriends car...I was gonna get another PS2-520 but that is like 100 bucks
    I had a 720 watt jenson a couple years ago...put out some decent power but also put out some good heat. That sucker would get so hot it would shut off into protect all the time during hard playing...the heat sink was a very bad design...most of the surface area was on the bottom with a few fins on two sides
  7. chance94z
    Make it $60 shipped and I will do it.
  8. aznboi3644
    60 shipped????
    I'll do it...if you can show me some legit pics of the amp with a paper with your screen name in the frame...
  9. chance94z
    I am also selling this on ebay. If you would feel safer going through ebay fine with me. Item number 230117472503. If not tommorow after I get home from work I will uninstall it from my truck and take a picture with my screen name in it.
  10. aznboi3644
    I hate paypal lol
    money order???
  11. chance94z
    that will be fine. I thought pay pal was actually pretty good, but I guess to each his own.
  12. aznboi3644
    Well...my mom gets my bank statements and always gets ****ed when she sees I spent more money on car audio lol...so I'm also trying to keep this on the low from the parents
  13. chance94z
    thats fine. did you want to go through ebay to finalize this or do you just want me to end the auction?
  14. chance94z
    I am going to bed, I will get back on here tommorow afternoon and see what you decided. thanks.
  15. aznboi3644
    just end it...cuz I'm for sure buying this.
    This amp works like its in perfect condition right??
  16. chance94z
    Yes it works fine. email me at chancehd@yahoo.com and we will get all the details taken care of. Thanks.
