First amp and sub install, not going well!
Discussion in 'Car Stereo Amplifiers' started by smokeeman33, Jul 14, 2010.
  1. smokeeman33
    smokeeman33 New Member
    When you stop laughing at my misery, maybe someone could give me some suggestions! My son just upgraded to a larger amp in his Jeep. A friend of his wired it for him. I'm a fairly intelligent guy, simple job, I don't need any help...My '06 Jeep Wrangler still has the factory unit and speakers, so I figured I'd put his old amp to use. It's a MTX Thunder 240. Basically, all I wanted to do was add the amp and a single sub. I just put Pioneer speakers in the overhead boxes and would like to get a little more low end and volume to overcome the wind noise. No big deal. Three and a half days, two complete installations and removals, and a third partial install, (still under way) later...it comes down to this.
    I knew I had the power wired correctly. 20amp fused + from battery, grounded to bare metal on chassis, remote wire from a switched + in back of head unit. Amp comes on and goes off when it's supposed to. Good to go! However, when I hooked up the sub, 12" 4ohm, using the bridged diagram on the amp ( + L to - R) the amp just started vibrating...rapidly. So, I tried to just hook it up on the R channel. One way simply pulled the cone in, one way, pushed it out, but no sound. I have un-wired and re-wired the input wires twice to make sure I had the +R and +L ( spliced into the rear speaker wires) and both -'s together on the gnd pole. ( the wires inside the speaker boxes come from a plug and are different colors than the actual wires, and after splicing into them with black wire, I taped them all up without writing down which was which...duh) After hours...and hours of diagnosing and frustration, and finally being sure the input wires were correct, I put a voltmeter on the speaker outputs. The right channel shows nothing? And the left shows over 20 volts! The amp was working fine in my sons jeep, so what I can't seem to figure out is, 1) Is the right channel fried? and B) What fried it?
    So, rather than bridge it, I just hooked the sub up to the Left outputs. It works for now, but I haven't tried to set it up yet. I still have to get a box. My other question is, will the fried channel damage anything else if I use it this way for now, and how much would a repair likely be if it's just maybe a transistor?
    Other than all that, I've enjoyed the install, and am now thinking of redoing my whole system. Man, how well do you thing that will go...
