Fiberglass vs. Wood
Discussion in 'Subwoofer Box and Custom Fabrication' started by MTX4Life, Dec 19, 2009.
  1. MTX4Life
    MTX4Life Full Member
    I love tha look of fiberglass (i mean who doesn't?) But I'm wondering how it sounds.. Never heard one, but thanks to tha internet, i've seen plenty.. But me personally would choose sound over looks any day.. So I was wonderin if fiberglass was worth all tha trouble, or should I just stick to wood?..
    also why is it when you do multipul subs in a fiberglass enclosure, you don't need a splitter or a port or anything? would that not damage tha subs?..
  2. Ranger SVO
    Wood (MDF) is much easier to work with. But as far as the sound goes, there is no real difference ( as long as the boxes are built correctly). Fiberglass is much harder to work with but the end result can be spectacular.
    I like making glass boxes, but it does take time. So if your in a hurry forget it. Also there is a little bit of a learning curve, but again the end result is an awesome looking box
  3. pedro quiroga
    if all the subs are wired together to one channel then no, they dont need a splitter.
    as far as needing a port..... the boxes you saw must have been sealed then.
    ive seen a few sealed and ported. mdf and glass. when someone builds a glass box its for looks mostly.( in the ones ive seen) or to fit multiple subs on the face of a box.
    they will and mostly do sound the same if built correctly.
  4. MTX4Life
    I'm still confused on tha splitter thing.. I've seen and even had one box that was sealed with no splitter, and I almost ruined a sub because tha two were beatin off each other so hard.. So if tha boxes work about tha same, I'm still not sure why a sealed glass box wouldn't need something to break up the air flow from each sub..
  5. pedro quiroga
    was it wired wrong? or were the two on different amps?
    im sure you may be confusing a splitter with a brace. if not, i think some people might separate the chambers if they have 2 diff amps running multiple subs.
    if one were to stop working it wouldnt affect the other sub. hope that helped.
    i dont think i mentioned this, but all my subs are in one large enclosure with some bracing. this keeps the box from vibrating a little.
    now if i ever went to two diff amps to power 2 subs each i might think about a new box to seperate the 2 pairs.
  6. MTX4Life
    Ha I'm still kinda confused man.. Sorry if it's frusterating.. I guess you'd have to see what I'm talkin about to understand what I'm asking.. Without a splitter in my own box, when it hit, one speaker would go in, and push the other out, and vice versa.. they were both hooked up on tha same amp.. it was doin it in tha box tha guy i got em from and in mine untill i put tha splitter in it..
  7. Ranger SVO
    They were wired incorrectly.
    Two woofers in a box, with no divider, act as one. They do not work against each other.
    Properties for two woofers in a single enclosure (from the Loud Speaker Design Cookbook by Vance Dickenson ISBN 0-9624191-7-6 Oct 1991)
    E. Sensitivity will increase +3 dB for a parellel connection and decrease -3dB for a series connection when compared to the single woofer
    F. Cone excursion will be half that of a single woofer enclosure.
    I only included the last two properties listed because these apply. For the last two properties to be true the woofers have to work together. If the box is divided, there is no sensitivity increase. Also excursion would not decrease.
  8. MTX4Life
    I think I'm startin to get it..
    But what was up with em beatin opposite each other? And when exactly is a splitter needed?..
    Once again sorry if this is a bother.. Just tryin to get a good grip on it.. Lol :(
  9. jonnyv713
    say u have 2 subs that are 4 ohm SVC, to make a 2 ohm load you wire them parallel. all the positives together. now, say u wired one sub the opposite. in this case off the positive terminal on the amp to the positive of one sub and the negative of the other then the same for the negative. this means the subs are 180 degrees out of phase. basically when one sub hits out, the other will hit in causeing cancellation.
    sorry, that may be hard to follow.
  10. MTX4Life
    It really did.. I'm really new to all this so it's all like another language.. But I'm comin along.. I think I got it.. I just need someone else to help me hook up next time.. I might have made a mistake bridgin it..
  11. Ranger SVO
    In my opinion the divider is not needed. I have found that larger enclosures perform better. When we divide a box, what we have are two small enclosures and smaller enclosures are a little peaky and they don't get as low as a larger box. Also there is no relative gain.
    When we put two or more (not more than 3 or 4) woofers in the appropriate sized single enclosure, we get relative gain (its louder), it plays across a wider frequency range (it hits lower), and its smoother.
