fiberglass sub box
Discussion in 'General Car Audio Discussions' started by pontiac_fiero_g, Mar 14, 2007.
  1. pontiac_fiero_g
    pontiac_fiero_g Full Member
    how do you calculate volume of a fiberglass sub box?
  2. DaveDSMer
    DaveDSMer Full Member
    depends really is it a normal shape or some off the wall shape.
  3. pontiac_fiero_g
    it is to be fitted into the corner of my trunk so it will be very rounded and curvy. also is it better to put it into the front firing towards the back or the back firing towards the front? i will probably put two individual subs one in each corner if that is not wrong.
  4. aznboi3644
    get packing peanuts...fill the box up and then dump the peanuts into a cardboard box...Volume equals area times height...then divide by 1728 (1 cu ft) to get internal volume
  5. pontiac_fiero_g
    awesom i would have never thought to try that thank you.:) is it better to fire forward of backward?
  6. aznboi3644
    depends on vehicle....what you can do is build a sealed box and play a song and keep changing its position and firing directions.
  7. pontiac_fiero_g
    sill probably build two small fitted boxes that are molded into their corner unless this is a bad idea. it is going into a 1997 pontiac grand prix 4dr.
