enclosure calculator
Discussion in 'Subwoofer Box and Custom Fabrication' started by cccullen, Mar 25, 2008.
  1. cccullen
    I don't know if any of you have tried this. It's kinda interesting.. I went on to the Re audio site and found the RE enclosure calculator. I was messing around with it and put some box dimensions in it. this is what i put"
    Box width: 49"
    Box height: 14"
    Box Depth: 20"
    Thickness: 0.75
    Square port width: 6"
    Square port Length 2: 9"
    Comes out that the box would be:
    4.958 cu. ft.
    tuned at 32.2589hz
    Thought it's pretty cool. It even gives you the cut sheets. I wonder if it's accurate. It doesn't say anything about bracing though...
    Anyhow, here's the link:
    RE Enclosure Calculator
    cool.......
  3. cccullen
    Im having a lot of fun toying around with it. oh, it doesn't give you a cut sheet it gives you the measurements for the cuts. Same thing actually, just wondering if anybody knows it the computations that this program does is correct.
  4. cccullen
    Just wondering if anybody would know if this would be ok for my kicker L5 15". I'm just trying to learn.
    box width: 49"
    Box height: 14"
    Box depth: 20"
    Port width: 6"
    Port length: 6"
    Box volume: 5.03 cu ft.
    tuned Freq: 33.135hz
  5. electrolytic
    electrolytic Full Member
  6. cccullen
    I think 6 cubes is the max required VentedSPL/Deep Bass. For the max of 6 cu ft. here's what i got:
    box width: 49"
    Box height: 15"
    Box depth: 23"
    Port width: 7.5"
    Square port length 1: 14.75"
    Suare Port length 2: 6"
    total port length: 32.75"
    Box volume: 6.051 cu ft.
    tuned Freq: 33.133hz
  7. pedro quiroga
  8. cccullen
    I just assume keeping it at 5 cubes which Azn recommended. When azn designed the box for me i wasn't thinking of the false floor (stupid me) which means the vent will be hitting the false floor. That's why i'm TRYING to figure out if i tune it at 33hz with a height of only 14" and a width of the whole 49" so i could possible put the box on the false floor. I think this may be right.
    box width: 49"
    box height: 14"
    box Depth: 20"
    wood thickness: 0.75"
    square port height: 12.5"
    square port width: 6"
    square port length 2: 6.0"
    total port length: 29"
    square port area: 75
    Square port volume internal: 2175
    box volume (ft3): 5.09
    tuned frequency (Fb): 33.135hz
    Again, i'm just giving it a shot with that calculator i found on the RE audio site.
    EDIT:: it's not right, i don't have the correct depth to get the woofer in with regards to the depth of the port. Sh*t!! gotta figure this out.
  9. cccullen
    I think i got it now....
    BOX WIDTH:: 40.0
    BOX HEIGHT:: 14.0
    BOX TOP DEPTH:: 25.5
    BOX BOTTOM DEPTH:: 25.5
    WOOD THICKNESS:: 0.75
    SQUARE PORT HEIGHT:: 12.5
    SQUARE PORT WIDTH:: 6.75
    SQUARE PORT LENGTH 1:: 18.0
    SQUARE PORT LENGTH 2:: 5.0
    TOTAL PORT LENGTH:: 33.875
    SQUARE PORT DIAMETER:: 10.36482448
    SQUARE PORT AREA:: 84.375
    SQUARE PORT VOL INT:: 2858.203125
    SQUARE PORT VOL DISPLACED:: 2874.890625
    BOX VOLUME (Ft3):: 5.02
    BOX VOLUME (In3):: 8675.109375
    TUNED FREQUENCY (Fb):: 33.0440409861915
  10. electrolytic
    yes that's for extra heavy duty super extreme loud ass bass lol, actually i just copied it from their manual for that sub. 5.0 should be plenty.
  11. GohillaAudio
    GohillaAudio Full Member
    yea, for real though, is this thing even close to accurate?
  12. cccullen
  13. aznboi3644
    the RE calc is off...I would never use it...pencil and paper for me
  14. GohillaAudio
    damn.....i hate math....lol i just need a simple 1.5 cu ft per chamber box tuned to 36 hz for 2 12's
