All of a sudden my CD player, power locks, and dome light quit working in my Chevy Caprice. I checked the radio fuse and the fuse marked power acc and they both look OK. The dash lights, power windows, wind-shield wipers and everything else work OK. One thing that concerns me is that the Optima battery Im using doesn't have deep enough side-post connections so there isn't really a good connection at the battery. Any ideas?
really sounds like a blown fuse to me. go through your car's owner's manual. There is probably another fuse to check.
Yes Soiunds like a Blown Fuse to me as well Have you looked at the Fuse box in the Engine Compartment? Many Cars have Dual Boxes, and in some cases Dual Circuits.... Also I woiuld HIGHLY recommend finding a Way to make the Connection at the battery the Best you possibly can Or you may one day come out and your car not start, all because of a bad connection you could be able to buy a Top Post mount, and Convery your car top post Or get a differant battery there are many other, and sometimes better, alternatives to the <insert color here> top
Thanks guys, It was a fuse under the hood that I didn't know about. I used some washers to get a good battery connection.
