El Camino....G-Body???
Discussion in 'Car Repair' started by beaux, Sep 22, 2002.
  1. beaux
    beaux Full Member
    Is an el camino a G body?
  2. sandt38
    sandt38 Full Member
  3. beaux
    beaux Full Member
    Where can i find some info on the axles? 26 spline, 28 spline?????????
    I found out on NastyZ28.com that I have 2.43 gears. There was some talk about finding a donor truck rear end with some lower gears to use the carrier. I've decided on 3.23 gears. Do I need a new carrier? what kind of truck should i look for to get a donor rear end?
    I was at the track and some of the guys where telling me that they just put spools in their cars. But I was reading in the summit catalog that says spools are for track use only.
    Do you have any other suggestions to get more rubber pulling?
  4. sandt38
    sandt38 Full Member
    I think the carrier will be OK up to about 343s, may be a bit lower, but you'll be OK with 323. Go to a boneyard, any posi 10 bolt with the proper gears will suffice. You will have to count your splines on the axle yourself, so far as I know, that is the only way to tell.
  5. beaux
    beaux Full Member
    SandT.....the guys over at the NastyZ28 forum are telling me that the lowest gears I can get in my carrier are 3.08's because its only a 2 series carrier. I want to put 3.23's in but I would have to get a new carrier according to those guys.
    How much difference would be noticable between 3.08's in my current carrier or 3.23's in a 3 series carrier?
    you can check out the thread here
    http://www.nastyz28.com/ubb/Forum12/HTML/002694.html
  6. sandt38
    sandt38 Full Member
    May be so. I am not used to gears that high. I'll look to see what would be required for a gear upgrade.
