its sticky on one side, you'll have to clean the surface first where you plan to lay it down. Then it is pretty easy to put it on. Not as easy as laying it down though. you're going to have to apply some pressure to hit all the curves on the surface so it will really stick. for the most part it is pretty easy but time consuming. You may also want to take a look a second skin. I heard it's cheaper and just as good.
What kind of Dynamat? The Xtreme sticks on easily, but the other stuff is junk, IMHO. Just clean the area first before applying like mentioned above.
whats the cheap stuff that somebody on here used at like home depo or something like that? i wouldnt mind using that cuz its cheap and your probably never gonna see it again.
i used a 13 dollar roll of flashing on my doors. was enough to do both my doors,rear panels behind my 6x9's and my tailgate. its in the roofing section. 12x 33 ft roll. i used this cause the other stuff was too much.60 or more for a door kit as opposed to 13. it helped with some rattling i had. i have a more solid midbass now. especially now that the doors are getting 100 watts each.
well i just bought 36 sq ft of the extreme off ebay for 150 bucks so ill hopefully try this weekend if it comes in
