I want to tell about how I listen DVD-audio in my car, where supported only audio CD. Converting DVD-audio tracks to WAV-files - go to http://www.foobar2000.org/download - download the foobar2000 program (latest stable version). - install foobar2000. - go to http://sourceforge.net/projects/dvdadecoder/files/foo_input_dvda/ - download the MLP-decoder plug-in (file foo_input_dvda-*.zip). - copy foo_input_dvda.dll in folder “c:\Program Files\foobar2000\components” For Windows7 – “c:\Program Files (x86)\foobar2000\components” - launch foobar2000 - go to menu File/Open. In opened window select file AUDIO_TS, and click button “Open”. Stop foobar2000’s playback of DVD-audio. - In the list there can be tracks in which name it is contained (stereo downmix). We sort tracks, having clicked on column's header "Title/Track Artist". Keeping a key <Ctrl> mouse click of the left button of the mouse we select tracks which we will convert. - By click by the right button of the mouse on any of the allocated files it is caused the contextual menu and we choose "Convert / …". Appear form “Converter setup”. - Select “Output format”: “WAV” and folder for output files (as example, “c:\audio”). - In "Specify folder' we choose a folder in which will be placed converted DVD-audio's tracks. In the "Name format" enter “%track %”. Now each file will have name as number of track DVD-audio. - If on DVD-audio there are tracks "stereo downmix" we pass to following goal (on tab Processing switch DSP should be necessarily switched off). Otherwise, we should transform a multichannel tracks into a stereotracks. For this purpose we open tab "Processing". We switch on checkbox "DSP". We mouse click on "Convert 5.1 to stereo" (in "Available DSPs") and we press the "<=" button. - Open “Other” tabsheet. Setup “Convert lossless formats” for maximum processing quality: * “same as source” – where “DSP” switched off; * “32-bit” – where “DSP” switched on. - Push “OK” button. We wait the terminations of converting DVD-audio's tracks in WAV-files. Sample rate conversion from DVD-audio to CD-audio - Go to http://audiventory.com/content/sample-rate-converter-48x44-free. - Download AuI ConverteR 48x44. - Setup and launch ConverteR 48x44. - Push “Open files” button and select all files in folder “c:\audio” (where lie output files of foobar2000). - We choose sample rate “44100 Hz”, bit-depth of sample (bit per sample) ”16 bit”. If you wish, it is possible to switch on dither for very easy transparency of a sound. Format – “WAV”. - We press "Start" button and wait for the converting completion. It is a pity that in the free version of this program there is no group converting of files. All converted files lie in a folder "c:\audio\ConvertResult". Record CD-audio - Go to http://www.cdburnerxp.se/?lang=en. - Download program CDBurnerXP. - Setup and launch CDBurnerXP. In appeared form click to “Audio Disk” row. In the left top panel we choose a folder with converted in 44100 Hz wav-files (c:\audio\ConvertResult). - Select by mouse all files in the right top panel and it is drag and drop them in the bottom panel. - Push “Burn” button. Appear “Burn audio CD” form. - Insert into drive CD disk. Push “Burn disk” button. Wait for record complete. THAT’S ALL. Somebody can will tell how to listen to audio DVD on car-audio only with CD support?
