dumb question
Discussion in 'General Car Audio Discussions' started by fstrfvo, Mar 19, 2008.
  1. fstrfvo
    fstrfvo Full Member
    When using line out converters, the head unit has 4 channels, 2 front, 2 rear, which would go to the 4 channel amp. there are no more speaker outputs to go to the sub amp. Would I just use the rca out on the 4 channel to the rca input on the bass amp?? Does it matter that the amps are different brands? Eclipse is the 4 channel and the bass amp is Crossfire CFA1000D, I put it back in when the Hifonics didnt perform as good as the old school Crossfire. I guess they dont build them like they used to!!
  2. aznboi3644
    doesn't really matter if you use either the front or rear for the sub amp...just use a short patch cable.
    Amp brands do not matter at all.
  3. pedro quiroga
    yes useing the pass out to the sub amp will work fine.
    there are no dumb questions...just dumb people.:eek:...:lol:jokeing.
  4. fstrfvo
    fstrfvo Full Member
    thanks guys ill do it that way!
