Dual 15's
Discussion in 'Subwoofer Box and Custom Fabrication' started by MikeNeufeld, Aug 13, 2007.
  1. MikeNeufeld
    MikeNeufeld New Member
    Going to be running 2 15's in an extracab toyota, and was wondering what the advantages of running a single chamber as apposed to 2 chambers would be... had planned on running each sub behind each headrest friing forward and with the port in the middle.... so would be seperate chamber... any input is cool..
  2. TheViking
    Its 6 of one and half dozen of the other........
    Bottom line is this, it wont make THAT big of a difference. I personally would opt for a box that uses 2 seperate enclosures however. THis would help to strengthen the enclosure and prevent unwanted and sound robbing resonance of the actual box itself.
  3. MikeNeufeld
    sweet, thanks, def will help make it more ridgid......
  4. irontodd
    irontodd New Member
    Plus, should one sub die in a combined chamber, the remaining good sub would be using double its recommended volume... not too good for the sub
  5. MikeNeufeld
    oh ya
    also, most guys telling me that these dimensions wont work for my 2 type r 15's... i got 48" wide, 28" height and 13 depth", to me it shud work, what yall think
  6. aznboi3644
    thats about 8.2 cu ft gross
    acount for port and bracing displacement you are nearing 2.5-3 cu ft per sub if going ported.
    IMO that is too small
