Downfiring driver mounting?
Discussion in 'Subwoofer Box and Custom Fabrication' started by Eleu, Jan 7, 2009.
  1. Eleu
    Eleu Full Member
    So whats the word on the reverse driver mountings in second and fourth order enclosures? is one better than the other? and is there any advantage to a downfiring sub?
  2. jonnyv713
    a reverse mounted sub just makes a little bit more airspace in the enclosure. not really noticeable sound difference unless you are doing SPL comps.
    also called power mounting
  3. Eleu
    Eleu Full Member
    so aside from gaining a 0.002% gain on internal area :p there really isn't an advantage? on a box design, do the designs change at all?
  4. jonnyv713
    not that i know of.
  5. G3n3R@1
    G3n3R@1 Full Member
    plus it looks kinda cool
  6. jonnyv713
    if the sub aint junk! thos eclipses would be sweet tho!!
  7. Eleu
    Eleu Full Member
    I am serious, those eclipses hold as much RMS as my MA12"s and are WAY cleaner and harder! I am worried about losing the brake light cover now. i was amazed.. I'm adding eclipse to the list of goods, ill have to check out the 12"s and 15"s they make to solidify it, but personally i think they are up there with kicks. plus the VC is guarded by some cool blue plastics heh be fancy lookin
