well i bought an amp tonight and was wondering how im gunna wire everything. i figured i would run my 6x9s off the amp, my four inch from the rear channel and my tweeters from the front channel. what you think? oh its a four channel amp which im going to need splitters for to get the four channels but ill only be running 2 6x9s from the amp for now. i might get a sub or 2 more 6x9s at a later stage
run the 4's and tweets on the front ch's off the amp and the 6x9's on the rear ch's. simple enough i think.
sure, you dont want the 6x9's over powering the rest of the system. just make sure the crossovers are set right and also the gains and you'll be a happy camper im sure. when the time comes for a sub you have 2 choices. 1) run it off of another amp. 2) run it from the rear channels of the amp and run the 6x9's off of the deck power. when you run rear speakers they should just give you a hint of sound. a filler if you will. thus its name. rear fill.
