I just installed the Pioneer Avic-D2. Is there a way to bypass the lockout on the D2 like the D1??? PLease Help. I have already done a search for this and have found nothing.
# AVIC-D1 lockout bypass: Find an extra Pioneer wire harness, and pull one of the wires out. Or, if you do not use the A.ANT lead, pull that out of the harness. # In the AVIC-D1 harness, there is one open spot on the connector (next to the ground wire). Put the wire into the open spot on the connector, connect the other side to ground, then re-connect the plug to the AVIC-D1. # Also, you must ground the Parking Brake wire (or connect to a toggle switch if you feel the need).dB FM sensitivity 8 dBf. IT SHOULD ALSO WORK FOR THE D2 i think...
