/ Register
Curious about buying components
Discussion in 'Car Stereo Speakers' started by wrathofthesun, Feb 18, 2009.
  1. I was debating on buying some Infinity Reference 6020cs components. Have been out of car audio for a couple of years and was curious is I could make either of these amps work for them. (Already own amps thats why) here are specs any advice would be helpful.
    Infinity reference 6020cs
    2-way external crossover network (18 dB/octave, 3,500 Hz high- and low-pass)
    2-ohm impedance for extra power (compatible with all factory or aftermarket car stereos)
    tweeter adjustment circuits (0, -3 dB)
    power range: 2-90 watts RMS (270 watts peak power)
    frequency response: 53-21,000 Hz
    sensitivity: 93 dB
    Maximum Power Output 800W (400W x 2Ch)@ 2 OHM
    Power Output
    260 (130W x 2Ch) @ 2 Ohm
    180W (90W x 2Ch) @ 4 Ohm
    Bridged Power 260W x 1 Ch @ 4 Ohm
    2 Ohm Stable Stereo
    Tri-Mode Capable
    Fan Cooling System
    Varible Bass Boost: 0-18dB
    Varible Bass Frequency: 30Hz-100Hz
    Channel Separation: >60dB
    Signal to Noise Ratio: 90dB
    THD 0.03%
    Frequency Response: 20Hz-20KHz
    HPF: 50Hz-1KHz
    LPF: 30Hz-250Hz
    Adjustable Sensitivity Range: 0.1V-1V
    Input Impedance: Low Level (10k Ohms) - High Level(100 Ohms)
    or a Boss chaos C450
    bridged 600x1
    peakpower 300x2 @ 2 ohms
    Rms 110x2 @4 ohms
    signal to noise ratio 102 db
    THD 0.01%
    Thanx
  2. cccullen
    Infinity are still good. some people say that their highs tend to be a little bright but it all comes down to preference.
    the best advice anybody could give you is to let your ears be the judge. what's your budget?
  3. Im working with 100-150 for right now, just trying to get the stock speakers out without breaking the bank. I listen to alot of punk, classic rock (Zeppelin), hard rock,metal, and a little rap. Not looking for bass out of themjust highs and mids, I always remember my buddies infinties just screamed. I saw a deal online in crutchfield they were originally marked at 199.99 but cut down to 149.99. saw another set of same new speakers for $105 including S&H
  4. cccullen
    I would get them then. If you've heard them and you like the sound then i'd say go for it.
  5. thanx for input I did go ahead and purchase them now I am anticipating them in mail.
