2 kenwood w3011. 400rms. Powered by this 2x 400 rms. http://www.hifi-tower.co.uk/Crunch_...0_4037_0.htm?campaign=pricesearch/cj/10003184 dosnt state bridged 2ohms. Only unbridged 2ohms or bridged 4ohms any one know why? How good are crunch. also always looked at rms on sub and tried to match to amp rms. Is this right? As this amp runs 2x4ohm at 400w each. So perfect for the 400rms sub?
or found this one Planet Audio AC3000.1D http://www.sonicelectronix.com/item_25314_Planet-Audio-AC3000.1D.html RMS Power Rating: 4 ohms: 1000 watts x 1 chan. 2 ohms: 1500 watts x 1 chan. 1 ohms: 2100 watts x 1 chan. Max power output: 1 ohms: 3000 watts x 1 chan. or a little more on cash Planet Audio AC4000.1D RMS Power Rating: 4 ohms: 1500 watts x 1 chan. 2 ohms: 2000 watts x 1 chan. 1 ohms: 2000 watts x 1 chan. Max power output: 1 ohms: 4000 watts x 1 chan. http://www.sonicelectronix.com/item_25313_Planet-Audio-AC4000.1D.html so for 10 more dollars. or £10 or so pounds. am i better to get the 4000 model for future use with bigger better subs. or run the 3000 model as 1500w is more then enough for what id ever want, if it ran two 750w rms subs. itd be way over the top for playing bass for my plesure!
