http://www.onlinecarstereo.com/CarAudio/p_25583_Crunch_P1-20001.aspx http://www.sonicelectronix.com/item_3981_Audiobahn-ALUM10N.html willthe amp push out a true 2000 watts? was looking at the hi phonic amps but for 100 dollars you cant really beat this amp along with the 64 dollar subwoofers do tyou think this is a winnner any other suggestions or feedback is welcomed thanks
the amp you are looking at is not true wattage (not cea-2006 certified) crunch is probably the lower end brand owned by Maxxsonics, I've seen more crunch amps NOT turn on than turn on.... so buy at your own risk, as far as the sub, i've owned one of those, good sub. probably that cheap simply because audiobahn is no longer is business.... but the sub is good regardless
what 1 ohm amp would be able to power these subs thats near on or alil above 2000watts rms for 3 10's would be 2400 im not so anal i have to have a 2400 watt amp so 2000 watts give or take should be fine for me
heres a couple of links to amps that meet the requirements for what you asked http://www.planetaudiousa.com/main/591 (do not cut corners and get interested in the anarchy Planet Audio amps), http://www.sonicelectronix.com/item_23549_Hifonics-Brutus-BRZ2100.1D.html, they are both cea-2006 compliant (true wattage) and both decently priced. ive used hifonics before i approve
