Crunch 15" Ground Pounder Specs for box
Discussion in 'Car Subwoofers' started by unknown007, Mar 31, 2009.
  1. unknown007
    unknown007 New Member
    Hi welcome myself to this forum.
    I recently purchased one GP15D2 since I got tired of using two 15's.:D
    Here are the specs I found:
    # Peak power: 1400-Watts
    # RMS Power: 700-Watts
    # 15" Ground Pounder
    # Blue Illuminated Titanium Treated Rigid Polypropylene Cone
    # Blue Illuminated Glass Kevlar Woven Dust Cap
    # Long-Throw 1.2" Butyl Rubber Surround
    # Integrated Spider & Tinsel Lead Assembly
    # 2.5" 4-Layer Dual Voice-Coils On Aluminum Voice-Coil Formers
    # 100-ounce Magnet Structures With 3600 Venting
    # Chromed Back Plate With Ground Pounder Style Rubber Boot
    # Black Chrome Steel Basket with Vented Inserts
    # Push-Terminal Connections for LEDs and Speaker Leads
    The amp I will be using is the P1400.1 Crunch amp.
    Specs:
    * 2/3/4 Channel operation
    * Power @ 4 Ohm: 700W x 2
    * Power @ 2 Ohm: 350W x 4
    * Power @ 4 Ohm: 175W x 4
    * Bridgeable amplifier topography
    * MOSFET outputs
    * Illuminated Crunch logo
    * PWM digital power supply
    * High-level inputs for OEM radios
    * Fully adjustable crossovers, Hi-Pass and Low-Pass.
    * Silver RCA line inputs & outputs - permit amplifier daisy-chaining
    * Silver power connections
    My conclusion is they push 700RMS.:D Im happy if that's true.Well on topic anybody somehow know all the spcs for the subwoofer?I'm trying to make a good box for it.I used two programs WinISD and AJ vented designer but am very lost on the graphs.I am going for a vented box not sealed.Thanks in advance.
    If you've made a good box for it specs of it would help thanks.
