couple questions.
Discussion in 'Car Subwoofers' started by connerray2010, Nov 8, 2010.
  1. connerray2010
    connerray2010 Full Member
    1)i have 1 kicker L5 12" sub in seald box with very little trunk space so i was wanting to know if i put poly fill in the box and put a port in and put a grill at the front or back of the port, will this work to make the sub think its in a bigger box and the port still work?
    2) the other opptin i thoght about was taking the spare tire out (but i know as soon as i did i would have a flat. should i go through with it?
    :huh:
  2. Ranger SVO
    What dimensions are we dealing with?
  3. TheViking
    connerray, are you perhaps refering to an aperiodic membrane?
  4. connerray2010
    Around 2~2.5 cf. "Viking" I'm not sure if its called that or not. Its the same stuff that's in pillows. There have been lots of people that do this on seal sub boxes but never head of anyone doing it in a ported box.
  5. 6.5ldiesel
    6.5ldiesel Full Member
    Im sure it can be done, but i imagine it would blow out the port if not secured properly, you can buy polyfill sheets (about an inch thick) that can be glued and stapled to the interior of the box that could work..
  6. connerray2010
    Well it not just put on the sides of the box. The box is completely filled (I think 1lbs for ~1.5cf. So about 1.25lbs in a 2cf box. I'll give it a shot and see if it works.
  7. 6.5ldiesel
    Let us know how that works out for you
  8. connerray2010
    Done some research and found people that say yea it does help and some say no just put some type of dens foam on the inner walls of the box (from what I gather its to cut down on echo coming out of the port and help flatin the bass spurts a little bit to give it more of a clean sound but also have good spl as oppose spl with sloppy rumble) help me to understand this better if I'm wrong.
  9. 6.5ldiesel
    I would build a custom box to your needs instead
  10. connerray2010
    Well kicker recommends 2.5 cf I think for the 12" L5 and my box is 1.9. Its in the range for porting but I whant it a lil big to get to the "g spot" for the subs recommended size. But I just can't go no bigger. Why you might ask. Well because when it comes to the "ol lady" and her trunk space or my sub box being big she wins lol.
