Connecting Amps To A Stock Hu. Help!!!
Discussion in 'Car Audio Head Units' started by cccullen, Jan 19, 2007.
  1. cccullen
    I've never attempted this so i just have to ask this question even though it may be a dumb question. I own a '01 expedition and as some of you may know i planning to set it up. For now, i want to keep the stock HU in it (i'll change it later). Now, the ford factory HU's don't have RCA connections so how can i hook up 2 amps if i there are no RCA connections? Right now i have a powered 12' sub using hi input but if i'm going to change it i'll definately have to use RCA's. HELP!
  2. cccullen
    To do this will i have to use a Line Output Converter (LOC)? how many?
  3. pedro quiroga
    yes you will. how many amps will you be useing?thats how you'll know how many converters to use.
  4. cccullen
    ok, so i'm going to use 2 amps so obviously i should use 2 converters. how much do they cost? have any idea?
  5. DaveDSMer
    DaveDSMer Full Member
    The PAC OEM-2 works great. Crutchfield has it and I installed one in my girls car and it works perfect. So many options with it. It has an advantage over the Trock Loc in that in can splice into front and rear speakers for front and rear RCA output. So since you have 2 amps that may work out better.
  6. cccullen
    cool, thanks for the information.
