component and amp ?'s
Discussion in 'Car Stereo Speakers' started by plumcrazylx, Jun 14, 2009.
  1. plumcrazylx
    plumcrazylx Full Member
    I just picked up 2 sets of alpine components (sps571) for my explorer. When I was questions a salesman at Best Buy, he said you HAVE TO run an amp with components. The salesman at the stereo shop said it was not necessary but would make for a better sounding system. I do want to add an amp just can't afford it just yet. Anybody's thougths and opinions are appriciated.
    thanks
    Ryan
    you dont need an amp just yet. run it with out an amp for now. the amp will give you more headroom is all. at reg normal listening levels it will work just fine.
  3. cccullen
    when i bought my first set of component speakers i didn't amp them. there may be some distortion at high volume because the component speakers are higher wattage but other than that, you should be fine until you can afford an amp.
  4. plumcrazylx
    Thanks
    Its gonna be a couple weeks before I can get time to put them in, so I might get an amp of ebay. If I find one cheap enough then I'm not out that much if it doesn't work out that great.
  5. pedro quiroga
    i did a set of doors in a mountaineer in an hour. its real easy.
    when buying an amp dont buy a cheap POS.
