Common Car Audio Mistakes
Discussion in 'General Car Audio Discussions' started by Caraudiotalk, Mar 20, 2006.
    Choosing a new car audio system can be tricky business. Most people make many mistakes when choosing their car audio system. Below are the most frequent mistakes made my car owners in choosing a new system.
    Many people just spend too much and in some cases go into debt. What can make this particular situation worse is that people go into debt for a system they realize they do not even like. First, figure out how much money there is available to spend. Then decide how much of the car audio system needs to be replaced. At this point plan a budget – how much can you afford to spend? Therefore you can locate system components in your price range. Deciding what is most important in the car audio system and plan to spend more on the important items. Going over budget is the first and most common mistake car audio system buyers make.
    Another thing to consider is how much of the car is going to need to be modified for your potential choices. For example some speaker installation will require many modifications to be made to the car. Modifications will need to be made by a professional and therefore you will have to budget into the total cost of the car audio system parts as well as labor. Another car audio systems mistake is that the owner of the car does not think about the future. How long are you going to keep the car for? Will you sell the car with the new audio system or will you remove it before sale? Remember audio systems never increase the value of a car enough to balance what was spent on the audio system in the first place. Also, if you plan on remove the system before you sell the car that could be problematic. Having a radio and an audio system are high priorities when people are searching for a new car to buy.
    When and for what do you use the car for? If the car sees a lot of use as well as wear and tear then buying higher quality components like speakers is a great idea. Understandably if you are spending more time in your car then at home you want to make sure it is as comfortable and entertaining as possible. However, if the car is only used for weekly shopping, low end parts are more appropriate.
    Another car audio system mistake people make is choosing a system which is not appropriate for the type of music they listen too. This is probably the most important factor which should influence the choice of the right car audio system. If the music that you enjoy is strong bass beats then a high end power amplifier is needed. Also, subwoofers would also be a good choice. However, if your music choice is at the opposite end of the music range then you will need a different audio system setup. For example, if you listen to classical music or trendy pop music, you will need to get a car audio that has a strong speaker system that offer even play of the sound spectrum.
  2. clipser-gs-t
    clipser-gs-t Full Member
    Very good write up joey. Spending that kind of money, for those kinds of results are foolish. I'm gonna go out on a limb and say no one on this site has enough money to be that foolish with anyways.
  3. 1wykdmk8
    1wykdmk8 Adminstigator
    Joey does......don't bother askin him...he will lie and tell ya he does not......:huh:
    See what I mean....
  4. ReMi
    ReMi Full Member
    Very good write up. I don't know how many times I had to explain similiar things to friends. They sometimes don't listen to me and go into debt trying to buy things they don't need. Crazy people!
  5. Attack Eagle
    Attack Eagle Full Member
    I'd like to add my favorite..
    Thinking wattage = quality or loudness.
    and second favorite
    Thinking x brand makes the best of everything from speakers to amps to subs. or that everything has to be the same brand.
    3rd
    "my friend says"
