Check my thinking on this
Discussion in 'Car Stereo Amplifiers' started by LarMoeCur, May 21, 2010.
  1. LarMoeCur
    LarMoeCur Member
    I think, I have this worked out but check my thinking. :wacko:
    Long story short due to a faulty install. My JL 500/5 bit the dust :mad: I'm pulling it out and sending it in to get fixed. In the mean time, I got a PowerBass ASA 1100.5. More power but not sure how clean it will be.
    Anyway, the vehicle is a 2004 Dodge 1500 Ram. The fronts are Polk Audio DB691 6x9 (4 ohm), rears are Boston Acoustic pro50se 5 1/4 (4 ohm), my sub is a JL Audio Stealth Box with 10W3v3-4 wired 4 ohm mono.
    The Powerbass will run in three settings
    4 ohms: 75 watts x 4 chan. + 250 watts x 1 chan.
    2 ohms: 150 watts x 4 chan. + 500 watts x 1 chan.
    4 ohm Mono: 300 watts x 2 chan. + 500 watts x 1 chan.
    Now to get 500w to the sub, I'll have to bridge the front and rear channels? running 4 ohm mono, Correct? Now the Polks can handle the 300w but how would it sound in mono? I could run the front and rears at 2 ohms but this will do me no good because the sub is 4 ohm. Is my thinking correct?
    Thanks
  2. fstrfvo
    fstrfvo Full Member
    Is there anyway to run the 4 channel in stereo and the sub channel in mono?
  3. LarMoeCur
    LarMoeCur Member
    That's what I was thinking. I just don't see a way to run 4 ohms with the sub at 500w unless I bridge the channels. I maybe reading the instuctions wrong but that's what it looks like to me. I'd ask at Powerbass but it appears their website is down.
