I have a 2002 Mountaineer with the stock in-dash 6-disc changer. It seems to be skipping every CD I own. I have only tried burned CD's so far, but I did not think that an '02 would have problems playing burned discs... I can not figure out why it skips all of my CD's, I have used the CD player cleaning disc, which did not help at all. It will play the first track with no skipping, the second track with very little, the third with quite a bit, and the fourth one is not playing more than it is. It will do this with all 6 CD's. I burned 6 new discs tonight to make sure they would not be scratched (new package of CD's). Anybody have any idea what might cause this....
Could it be that particular brand of cds? My friend has that same year mountaneer and it plays cdrs just fine.
Well... It The nicer the brand of CD it is the better it will play. What is the nicest brand of CD's that I can buy? It can't hurt to like buy a 5-pack and see...
Yeah, It will play the Memorex CD's decently, but it will still skip quite a bit on those. I think there is just something wrong with the CD player itself... it is not a big deal, the local Ford Dealership said they can replace it for $25 if they can keep the one I have in it now
the problem is the Way CD'rs are Recored over CD's Pressed the CD'r need a Stronger Laser to Read them propery, and if your using a High Speed Burner (30X or more) the Laser needs to be even stronger Burn a CD at a lower Speed (16x or lower) and see if it fixes the problem, alot of stock players still have CDr issuse becuase of the weaker lasers
