Cap or distribution block?
Discussion in 'Automotive Electrical' started by trance86, Jan 12, 2012.
  1. trance86
    trance86 Full Member
    I have a 250amp alternator with big 3 and 0 gauge wire running to my 1 farad capacitor and my lights dim and dash volt meter drops everytime bass hits. It immediately replenishes but it is still noticable after upgrading the alternator. Ive heard that caps are a waste of power.. Should I get a bigger cap or cancel it out all together and use dist. block?
    how big is your system?
    also i don't see how adding a dist. block will help with your lights dimming.. what you should look into is adding a second battery if your amp is power hungry.
  3. trance86
    Im running two amps, 600rms to my interiors and about 1800rms to my subs..
  4. kostyam69
    kostyam69 Full Member
    for that kind of RMS you definetly need an extra battery or 2, i recommend kinetik, stinger or xs power... im also trying out this Shuriken brand, not too bad, similar to kinetik but seems to be cheaper. ive got only 1000rms on my bass set up and i chose to use a kinetik and shuriken (each made for up to 600rms) HUGE benefits gained
  5. steve
    steve Full Member
    Extra battery, the alts output is to do with rpm's. The higher the more output and vise-versa.
  6. trance86
    Thanks! My biggest concern is for my summer vehicle. I had real trouble finding a high output alternator for an '86 nissan 300zx. Im going to be running 2200 rms total power with a 170amp alternator (the largest i could find). Is that alternator powerful enough to merit a second battery?
