/ Register
Can you tell me more?
Discussion in 'Car Stereo Speakers' started by kerns193, Feb 7, 2011.
  1. kerns193
    kerns193 Member
    I just purchased 2 brand new 12" TS-OX12 Audiopipe Subwoofers in a bandpass enclosure. Is that a good purchase? Im not looking to spend a fortune just something to give bass.
  2. kerns193
    kerns193 Member
    ooopppsss wrongs section of the fourms...
  3. tommy2tone
    tommy2tone Full Member
    I'm not familiar with that company,but one of the best systems I've had was a bandpass.
    Depending on what was paid for the setup makes a difference as well.
    Hook it up and see for yourself,let your ears do the deciding.
    What amp are going to use?
  4. kerns193
    kerns193 Member
  5. kerns193
    kerns193 Member
    Since im new to all this I have no clue what goes with what all I know is how to wire. I have looked all over the internet to find answers to my questions and theres nothing that helped. Sooo Im in the process of trying to figure out what amp and wiring kit will with do great with the subs I have.
  6. connerray2010
    connerray2010 Full Member
    Well, its always good to keep the wattage of the sub or in your case, the combined wattage of your subs close to the wattage of the amp (ex: two 100 watt subs= 200 watts). This HELPS lower the risk of blowing your subs remember I said helps lol. A good amp to match would be of the same brand, audio pipe. Set the gane on the amp properly, iv been told put a 50hz sound track repeat, turn your volume on your radio up 3/4, and start playing with the settings. Its hard to say what it sounds like when your subs "distort" but when and if you can hear it, back your gain off a little bit and you all set. O yea, for the subsonic and low pass fillters, most prefure I think 5 for the subsonic and 160-180ish on the lowpass. Good luck
