I was wondering how to calculate what the minimum relative cross sectional area any part of an enclosure can be, before the sound is affected For example, would this box shape cause any issues? If so, would it make any difference to put in some 45" pieces to smooth out the corners? What about using a wide port to connect two chambers together like this: How do you calculate the minimum cross sectional area B? Does the length C make any difference?
