Cadence Z1000 - anybody know how much power they a
Discussion in 'General Car Audio Discussions' started by kennyg, Feb 4, 2003.
  1. kennyg
    kennyg Full Member
    I was lookin at one, and a buddy of mine has one, and he wants to sell it for $100. i was thinkin about gettin it. First of all, how much power is it, cause it said on the manual, and on cadences website, that 2 ohm power is 300 watts, tyhen right under that, it sayd 2 ohm mono power is 400 watts? It's a mono amp, so I don't know which number to believe. Is this amp worth $100, and will it run at 1 ohm? Thanks.
  2. BlkX
    BlkX Full Member
    I just spoke with Mr. Sandt38 about this amp a few hours ago. According to Cadence's website, its 400x1 @ 2 ohms mono and according to Sandt, it is 1 ohm stable, and will double power at 1 ohm.
  3. BlkX
    BlkX Full Member
    Oh, and for 800w @ 1 ohm...why wouldn't you take it for 100 bucks?
  4. kennyg
    kennyg Full Member
    That little amp will run 800 watts at 1 ohm? I don't know about that, but ok. It only has a 30 amp fuse in it. Does this fuse size need to be increased to run at 1 ohm? thanks.
  5. BlkX
    BlkX Full Member
    I think sandt can better answer that question, but he did say you'd need to upgrade your inline fuse. I don't know about the fuses on the amp...
  6. kennyg
    kennyg Full Member
    sandt, can you help???
  7. kennyg
    kennyg Full Member
    SandT - Mike? Do either of you guys know about this little amp? PLease, any help woud be greatly appreciated, form many sources. Thanks.
