loyd runs his Z9000s (rated at 4 ohms mono) at 2 ohms for daily driving, and 1 ohm for comps :blink: . I don't suggest that, but it can be done. You can wire your subs to 4 ohms mono anyways, so it will work fine. Their amps are fairly accurately rated. They are slightly underrated, but you will not see them publishing #s like the JBL 1200.1 (1200 rated, 1460 accurate). They did that with the A7HC (1200 rated, now rated at 1400) but apparently they'd rather be accurate.
Hey Civic what are you looking to run? I still have my EQ 200dhc for sale, and that would give you 800-1000w @ 4ohm, give me a pm if interested
