so im thinking about my box dimensions for my 13w7 and i talked to this guy at a custom shop, he said that jl is "real strict" about their box dimensions and if i dont build the box to jl's specs, its going to blow. i wanted to build a box about 3.5-3.75 cu (maybe even 4 cu ft) ft tuned to about 38 hz. you guys think this is a bad idea? also, he also said that nobody uses box terminals anymore??? he said that i should just drill a hole in the side of the box, run the wire through and silicone it up....
this is regarding the terminals....... for me it was easier to drill a hole and silicone it up,only cause i used 8 gauge wire for my subs.
that's exactly what I used for both of my boxes... I got a question for all of you... what gauge wires do you use from the sub to the terminals? I find it really hard getting the wires to fit especially when i'm wiring my 13Ov.2's
thanks guys, i suspected that he was just trying to get some business from me, but i figured i'd ask you guys to get an honest answer..what a dick
