/ Register
Bracket Problem
Discussion in 'Car Stereo Speakers' started by YtseJam92, Aug 24, 2011.
  1. YtseJam92
    YtseJam92 New Member
    Hi there, I'm new here as most of you could probably tell. I am also new to DIY audio installations. My plan was to install my JBLs in my car (Toyota Matrix 03) this morning, however once I got the door panel off I noticed that the mounting bracket was fastened on by some sort of screw that has no place to "un-screw" it from, they look like washer with smaller holes in the middle. So I can't even get the old speaker out. I'd greatly appreciate any help I can get on this as I am quite sick of these old speakers. I apologize in advance if this is a rook question. I'd rather learn the had way than not get these installed.
    Thank you. :D
  2. Promodmerc
    Promodmerc Full Member
  3. TheViking
    You could also drill off the heads, like a pop rivet, then replace them with a more standerd screw
