box builders clear this up for me plz
Discussion in 'Subwoofer Box and Custom Fabrication' started by connerray2010, Feb 23, 2011.
  1. connerray2010
    connerray2010 Full Member
    got a new 15" atomic ele coming in the mail. here are the box specs
    E.L.E.15D- ported ? 3.25ft3 *2(4? ports x 15 ¾? long) (36Hz) F3=65Hz 1000w************************
    4.0ft3 *2(4? ports x 11? long) (36Hz) F3=66Hz 1500w (SB)************************
    4.5ft3 *2(4? ports x 9? long) (36Hz) F3=68Hz 2000w (SB)************************
    5.0ft3 *3(4? ports x 14? long) (36Hz) F3=65Hz 2000w (SB)************************
    5.5ft3 *3(4? ports x 11 ¾? long)(36Hz)F3=68Hz2000w(SB)************************
    5.5ft3 *80si x 10? long (55Hz) F3=42Hz 2000+w (SPL)************************
    6.0ft3 *3(4? ports x 10? long) (36Hz) F3=69Hz 2000w (SB)************************
    8.0ft3 *80si x 10 ½? long (40Hz) F3=36Hz 2000w (SB+)************************
    9.0ft3 *190si x 8 ½? long (55Hz) F3=43Hz 2000w (SPL)
    what a mess lol
    what i dont get is th "80 and 190si" on the 8^ft and 9^ft does this mean 80 square inch port, 80 wide, 80 tall?
    some one do the figures for me on the port for the 8^ft box plz and thanks
    o and what is F3?:confused:
  2. connerray2010
    lmao, the smilly is a b (sb
    i will tri to find the small perameters or what ever there called
  3. TheViking
    si seems to indicate "square inches" to me.......and you dont want a 8 or 9 cubic foot box...you would HATE it....
  4. connerray2010
    Revc (ohms ) 2.00 1.80 1.80
    Fo (Hz) 19.60 31.5 50.7
    Sd (sqM) 0.267 0.089 0.055
    Bl (TM) 28.24 20.36 20.06
    SPLo (dB) 95.30 91.2 92.43
    Xmax (mm) 15 10 10
    Dvc (mm) 100 75 75
    Qms (m.q.) 5.20 3.82 5.38
    Qes (e.q.) 0.266 0.42 0.37
    Qts (totQ) 0.253 0.38 0.35
    Vas (liter) 774 116 32.4
    Cms (uM-N) 76.5 103 75
    Mms (gram) 341 247 130
    here that is, and why would i hate that size viking?
  5. connerray2010
    B) = B ) stupid smillys lol
  6. connerray2010
    i believe the midel #'s are for the 15
    and i want the dest box for it to be as loud as possible
  7. connerray2010
    one more post i break 300!!!!!!!! ( just had to put that out there lol
  8. connerray2010
    BOOOOOOOOOOOOMMMMMMMMMMMM 300!!!!!!! lmao
  9. connerray2010
    BUMP? i know theres someone who can help
  10. steve
    steve Full Member
    running a 8cuft box is simply too large, the only advantage of a large box is a increased
    peak output at lower freq. however,this is true up to a point.too large of a encloser and
    the spk begains to unload (kind of like playing in free air). fb is enclosure resonance freq.
  11. steve
    steve Full Member
    my last post did'nt post,mabye it will this time-
    running a 8cuft box is simply too large, the only advantage of a large box is a increased peak output at lower freq. however,this is true up to a point.too large of a encloser and the spk begains to unload (kind of like playing in free air).
    the 8cuft box- a port 20in H x 4in W= 80 square inches,20H x 4w X10.5L..port size.
    fb=enclosure resonance freq , f3= freq cutoff or -3dbs
    E.L.E.15D- ported –
    3.25ft3 2(4” ports x 15 ¾” long) (36Hz) F3=65Hz 1000w
    4.0ft3 2(4” ports x 11” long) (36Hz) F3=66Hz 1500w (SB)
    4.5ft3 2(4” ports x 9” long) (36Hz) F3=68Hz 2000w (SB)
    5.0ft3 3(4” ports x 14” long) (36Hz) F3=65Hz 2000w (SB)
    5.5ft3 3(4” ports x 11 ¾” long) (36Hz)F3=68Hz2000w(SB)
    5.5ft3 80si x 10” long (55Hz) F3=42Hz 2000+w (SPL)
    6.0ft3 3(4” ports x 10” long) (36Hz) F3=69Hz 2000w (SB)
    8.0ft3 80si x 10 ½” long (40Hz) F3=36Hz 2000w (SB+)
    9.0ft3 190si x 8 ½” long (55Hz) F3=43Hz 2000w (SPL)\
  12. connerray2010
    what would you recomend? 5FT?
  13. TheViking
    4 cubes looka a good to me.....
  14. connerray2010
    tuning for sql/alot of spl
  15. steve
    steve Full Member
    manufacturer's recommendations are usually for a flat response, i never use them. if you could give me the spk specs(a little clearer) i'll see what i can come up with for you
  16. connerray2010
    Revc (ohms ) 1.80
    Fo (Hz) 31.5
    Sd (sqM) 0.089
    Bl (TM) 20.36
    SPLo (d 91.2
    Xmax (mm) 10
    Dvc (mm) 75
    Qms (m.q.) 3.82
    Qes (e.q.) 0.42
    Qts (totQ) 0.38
    Vas (liter) 116
    Cms (uM-N) 103
    Mms (gram) 247
    best i can do, only thing i under stand is 15", 2k rms, 1ohm dvc, 3" coil lol
  17. steve
    steve Full Member
    ok, i'll use these and see what i come up with, oh, what is the rms and peak wattage
  18. connerray2010
    2000 rms, peak i would say 4000
  19. morespl
    morespl Full Member
    dude in that car
    I would rec. the 4.5 2000 watts the reason is for that size trunk you will need to let the sub breath You start going with a gigantic box and you limit the air space the sub gets lower but the loudness drops out I learned this the hard way.The amp that your running is 3000 watts you drop voltage to the amp or have a week electrical the amp is still gonna push more than 2500 watts.Unless your sub is dual 2 and you plan on running 1 channel go with the 2000 watt enclosure. and in your trunk the car will play a factor so take demenstions and draw up a print make it with cardboard and tape to see how it fits.
  20. connerray2010
    Well, I'm going with the 4-4.5 cubes, 35hz tuning and callinig it love lol. I hate the box build part, but its the most important part of the sub
