Boston Acoustics GT-2200
Discussion in 'Car Audio Talk Homepage News' started by Caraudiotalk, Sep 10, 2010.
    $274.00
    2-Channel 900W GT Reference Series Car Amplifier
    • RMS Power Rating(14.4V):
      • 200W x 2 @ 4 Ohms
      • 350W x 2 @ 2 Ohms
      • 700W x 1 [Bridged] @ 4-Ohms
      • 900W x 1 [Bridged] @ 2-Ohms
    • RMS Power Rating(12V):
      • 160W x 2 @ 4 ohms
      • 750 x 1 [Bridged]@ 4-Ohms
    • Remote bass level input (GT-RSL Required)
    • Red LED power badge and orange protect indicator
    • 2/1 channel operation
    • Adjustable mounting feet (mounting feet move along rails to allow the easiest installation)
    • Fully computer-controlled diagnostics system (continuously monitors amplifier in case of thermal overload, short circuits, or over voltage)
    • Q-Tune technology combines sophisticated crossover adjustments with Q-Control settings to seamlessly transition rear bass to the front sound stage
    • Uses a 70 amp ANL fuse
    • Heavy duty fan cooled aluminum alloy heatsink
    • Gold-plated RCA level inputs
    • Gold-plated screw terminals
    • Variable high-pass filter (20-350 Hz, 12 dB/octave)
    • Variable low-pass filter (50-350 Hz, 12 or 24 dB/octave)
    • Signal Voltage Input (200mV-8V)
    • Frequency response: 10-95,000 Hz
    • Dimensions: 18-3/4"L*x 9"W*x 2-3/8"H
    • 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
