Bonehead question
Discussion in 'Car Stereo Amplifiers' started by xxxr, Oct 20, 2006.
  1. xxxr
    xxxr New Member
    Newbie question, but what the heck caused my Sony Amp to shut down? I'm assuming it's a breaker that pops at a certain level of power going through it. Only problem is that I'm not running it all that loud! I have it connected to one sub and a couple of front speakers. Nothing fancy at all, but it tends to shut down at about half volume. This is about as loud as my other vehicle with a STOCK stereo! (1994 Toy, somethig is definitely wrong) Any ideas? :huh: If I shut off the head, then it returns to run the amp without issue, only to shut down again if I don't turn it down some.
    Thanks!
    first off every one here will tell you that sony makes crap amps.sorry all. i beat you to it!
    ok.sorry.at what impedence do you have your speakers running?and what is your gain set at?
    does it have enogh room to breathe.is it too hot to touch when it shuts down? let us know then we can further assist you.
  3. xxxr
    xxxr New Member
    Not too happy with the head either, but that's what I got. Man... you're talking mumbo jumbo to me... I have no clue what that stuff means. :( I'll check if it's overheating though.
  4. Ranger SVO
    It shuts down with volume? How long does it stay off before it comes back on? How long does it work before it shuts off? a minute? ten minutes? more?
    If it shuts off after a minute I don't think its likely its overheating.
    I wonder if we have a speaker problem.
    Need more info
  5. DMP
    DMP Full Member
    The amps arent the only thing that they make thats poor quality. Id add in the speakers and subs too.
  6. aznboi3644
    How about all of their car audio is crap besides the head units
  7. pedro quiroga
    they may have good head units,but i just dont like thier looks.thats me though.
  8. Eclipsed
    Eclipsed Full Member
    I skimmed through all that, is the h/u going off or just the amp?
  9. xxxr
    xxxr New Member
    Just the AMP... comes back on as soon as I shut off the head, and turn it back on. Only happens of the volume is up a bit.
    It shuts down with volume? - Only if the volume is up more than half way.. not much!
    How long does it stay off before it comes back on? Won't turn back on until I shut of the head
    How long does it work before it shuts off? a minute? ten minutes? more? Until I turn off and on the head
    If it shuts off after a minute I don't think its likely its overheating. Won't shut off at all unless the volume is up half way.
    I wonder if we have a speaker problem. Hummm... should I look at the wires? Seems like a braker issue in the AMP to me... but I don't know much about this stuff.
    THANKS!!!
  10. Ranger SVO
    OK, the amp is going into protect. Now we need to know why. Disconnect both speakers. Turn on the radio and turn it up. Does the amp stay on? If the amp shuts off we have an amp problem.
    If it stays on, hook up one speaker. Does the amp turn off or stay on. If it shuts off, we might have a bad speaker. Check the Gain or Level control on the amp. If its turned up all the way turn it down to about half way and try again. Now does the amp stay on or shut off.
    If it shuts off we have a speaker problem. Only check one speaker at a time this way.
    I am assuming that all connections to the amp are good. Power and ground wires are the right size and the ground is actually bolted down to metal, not just rapped around something.
  11. xxxr
    xxxr New Member
    All looks good there on wiring. I'll try the tests and get back to you. THANKS!!!
  12. Willy D
    Willy D Full Member
    Do you own a digital volt meter??
    If not borrow one...Set your meter to DC volts on a scale of <20 volt....Connect the ground lead (black) of the meter to the battery ground..Put the red lead on the amp power terminal...What does it read? If it drops down real low when amp shuts off, you have a bad power lead...It should read 12-12.6 with engine off....If that is good, move the red lead of the meter to the remote turn on wire...See what that reads, before and after shut down...Does it drastically change? If so, the wire or signal from the head unit is bad...If ok, put the red meter lead on the ground for the amp (leave the black meter lead connected to the battery negative)...What does it read?? It should read zero...If not, the ground is bad...Try grounding to a better source....
    Willy
  13. DREAMZmustang
    DREAMZmustang Full Member
    it might have a bad ground,and there hu's maybe alrte but they feel really cheap when i touch them
