big diffrence? between 2 way & components
Discussion in 'Car Stereo Speakers' started by magnum340, Mar 20, 2008.
  1. magnum340
    magnum340 Full Member
    if there the same brand and size, is there a difrence in quality and or clearity? i just dont want to mess with a tweeter.
  2. bigsq
    bigsq Full Member
    what 2 way are you talking about?, because components are usually a 2way, or do you mean coaxial speakers, well thats what meant, then definitely component is better and more sq and gives you more option in imaging and staging,
  3. bigsq
    bigsq Full Member
    oops sorry i made a mistake their on the words , i meant well if thats what you meant
  4. pedro quiroga
    my guess would be a better crossover.for better sound quality
  5. bigsq
    bigsq Full Member
    well if you get a high end comps, its common that it would come with a nice x-over, try Bewith,CDT,zapco,dynaudio,diamond audio,pg
  6. magnum340
    For 99$ I Could Get A Pair Of Cdt With A Silk Dome Tweeter Wich I Herd Is Better Than A Hard Dome I Think.
  7. pedro quiroga
    i like silk dome over other materials.smooth sound not harsh.
  8. pedro quiroga
    i meant the crossovers are better than the cap the you get with coaxial speakers.
    99 bucks. nice! get em.:)
  9. G3n3R@1
    G3n3R@1 Full Member
    polk FTW, comps will pretty much always sound better. instead of a capacitor blocking the low frequencies for the tweeter you'll get a full fledged crossover and uses more octaves which usually produces a smoother sound. plus from what i've noticed comps have higher power ratings due to proper isolation of the sound frequencies to each speaker.
  10. pedro quiroga
    i wonder? do you get the same speakers from a coaxial set that you get when you buy a comp set?or slightly better?
    aside from the xover and tweeter mounting hardware.are they the same...
  11. G3n3R@1
    G3n3R@1 Full Member
    i wonder too, i bet some coaxials probly come with smaller tweeters.
  12. Ranger SVO
    Typically there is not that much difference. I really prefer co-axials. Thats what I use in my truck. Installation is greatly simplified. You dont need to find a place for a crossover and a tweeter. Also many components really need an external amplifier to sound there best, while most co axials are designed to work with deck power (addition power from an amp just makes them sound much better).
  13. pedro quiroga
    ok good to know
  14. G3n3R@1
    G3n3R@1 Full Member
    thanks for sharing that ranger!
