alright guys I need to get an amp that puts out 300x1@4Ohms for an MTX 5500 12" single 4Ohm in a 3cF sealed box THATS CHEAP and actually puts out 300watts. i've been lookin at a lot of stuff and i feel like theres other options that might be cheaper. any suggestions?
found it on ebay POWER ACOUSTIK PS2-520 CAR AUDIO 2CH AMPLIFER 520W AMP - (eBay item 140154816866 end time Oct-04-07 17:01:32 PDT) weird thing is, if you look at the PS2-600 it has less RMS wattage. its also the same price. what gives? Power Acoustik PS2-600 - 4 ohms: 95 watts x 2 • 2 ohms: 120 watts x 2 • Bridged, 4 ohms: 240 watts x 1 • PWM MOSFET power supply • High or low level inputs with floating ground • Tri-mode capable • Frequency Response: 10 Hz - 30,000 Hz - , Car Amplif
is this too much power? 07 PHOENIX GOLD RYVAL 500 WATT 2 CHANNEL CAR AMPLIFIER - (eBay item 270161801069 end time Sep-12-07 16:06:13 PDT) 500x1@4ohms.
NEW 06 JBL GTO75.2 II 2 CHANNAL AMP 260 WATTS ll GTS - (eBay item 290159841145 end time Sep-18-07 09:07:13 PDT) 290x1@4ohms
well really 250+ should get the job done but i need to keep it as cheap as possible without moving into the ****ty quality amps.
