so still new to the whole box fabrication deal... so if a driver calls for two 4" port and making a dual box. that would be 4 4" ports. now to change that to a slot port do I add all of that area together eg.(Pi x r(squared) by 4) also have a minimum port size formula. this look correct? dv>39.37*(Fb*vd)^0.5 dv=required diam of port Fb=tuning freq vd=X-Max in meters * sd and for port length Lv=[1.463x10^7*R^2 / Fb^2*vb]-1.463R where Lv=port length Fb=tunning freq vb=volume in inches R=radius for multiple ports devide enclosure volume by the number of ports. then use that as vb. for a square port R= sqrt of a/Pi where a is the area of square port. is this the formula you would use for a slotted port? or is a slotted port different? I know it would be a rectangle rather than square but would this give the same area? rather than 8x8 square port would a 16x4 be the same? these formulas look good? (ranger, azn?)
oh i waqs just wondering, those are the Formulas i use from the cookbook, just wondering if anyone else used different formulas, any input at any time is fine
forumals are good...as long as port area and length are the same...it doesn't matter what the shape is really. Unless its a really long skinny port.
