So here's my situation. Anyone have any suggestions on a set of battery terminals?? I need the "positive" terminal to have either two 8 gauge inputs and two 4 gauge inputs...or three 4 gauge inputs and one 8 gauge input. For the "negative terminal I only need two 4 gauge inputs. My battery already has my 8 gauge power wire + one 8 gauge and one 4 gauge (one is starter motor and one is alternator)...I need new terminals because I can't run a new alt-battery wire. Any suggestions...I found a Scosche terminal at Wal-Mart today for about 8 bucks that has two 8 gauge and two 4 gauge inputs. I don't buy car audio stuff from Wal-Mart though but it is my last resort to buy the Scosche terminals I just want some other opinions or suggestions...Thanks Oh yeah and if they came in a matching set that would be even better. Azn
Ok screw everyone...lol...went ahead and got some Scosche terminals since all of you suck balls and didn't help any. peace
Check out knukonceptz.com and check out the battery terminals. They are pretty nice, and they only cost 12 dollars.
hay, anz.. I got nothing bad to say about scoshe's terminals, blocks, wiring, etc.. seem to hold up a lot better than thier install kits.
Id say go with marine battery terrminals, ya know, the kind with the 3/8 " bolt and nut for the connection. They will generally carry more current than what a cheesy little set screw and hole will!!!!!! And please dont tell me you got the gold plated ones!
haha screw the gold...I just got the Platinum ones with two 4 and two 8 gauges...works fine. What kind of terminals do all of you guys use??
Stinger Expert Digital for the positive and Stinger Small Multi-output for the negative. http://www.stingerelectronics.com/web/prods/battery_terminals.asp
No way I could have only 2 outputs for positive...Factory alone has 2 wire..plus my power wire and new alternator to battery wire lol. But I could get those digitals for a kinetik battery in the future...friend of mine can get an HC800 for 100 and a HC600 for 80...good for me
