i have a problem with one of my sub amps...without rca's attached the amp has no problem maxin out but when i hook the rca's it clips at about half gain and i've reran rca's to head unit ...still does it...then i strapped the amps together and still same problem...other amp works fines both securely grounded and hooked off the fosgate 17volt capacitor...but i was thinkin about scrappin these two autoteks and runnin with the MA audio 4000.1....any suggestions
The gain is not a volume knob...I can make an amp clip with the gain and boost at minimum. You need to read and learn more about gain settings and how to set them. Read here please before you cook some stuff. Amplifier Gain Controls Setting Gains with an Oscilloscope (and a Spectrum Analyzer)
