automatic charging relay for dual battery setups interference in speakers
Discussion in 'Automotive Electrical' started by Rspoon, Apr 11, 2012.
  1. Rspoon
    Rspoon Member
    i have recently installed a dual battery setup in my 21 ft boat. i have 2 6x9's 4 5.25's 2 1000 watt amps and 3 10 inch subwoofers. The batteries are a deep cycle and a high cranking amp just for starting. in between the two batteries I have an ACR and a perko switch. my problem is that any time the alternator or on onboard battery charger is charging the stereo starts popping regardless of the volume level. i know the ACR is causing the interference but i don't know what to do about it. any help will be greatly appreciated!
  2. xlaudio
    xlaudio Full Member
    you need to install a relay sol go to wranglerpower.com i think i got mine from there works great
