Okay, first off I have an Audio Art 200.2RXT. This thing's underrated at 100x2 @4ohms, 200x2@2ohms, 350x2@1ohm. It will do 400 into 4ohm mono, and in excess of 700@2ohm mono. Has built-in crossover network also. This thing is a 9.5 out of a ten. It has a small scuff on one corner that is barely noticeable and is the ONLY imperfection on this thing. Asking $120 OBO. Next up I have 2 Motion brand linear actuators. These are 12V with a 6" stroke and a 75lb. workload rating. They are used but 100% working and in excellent condition. They have a spherical rod bearing on the shaft end. Asking $140 OBO for BOTH. Next I have a pair of RF HX2 8s. Now these are in need of repair. There is a small hole in one of the surrounds. Both have 1 voice coil on each that does not work. 1 is a simple fix and just requires the tinsel lead to be re-soldered to the terminal. The other I have no idea about. It just doesn't work. Now these are pretty beefy drivers and they worked well up until I realized that each one was only working on 1 coil. I'm looking to get $30 for the both of them. And last but not least, I have a K&N drop-in filter for a '89-'97 T-bird or Cougar. This is a used unit, but works fine. $20
ygm on the amp. one thing i forgot to ask tho...if using high level inputs, do the xovers still work? eric
well, im sorry man, but i ended up getting something else. i still had mtx stuff left over, so thats what i ended up getting. good luck sellin your stuff. eric
Very nice prices, and that amp is a classic... Do you happen to know it's year? It looks to be in absolutely mint condition... you won't have any problem getting that price for it - I didnt' even see the scuff? I'd seriously take that amp over a Tru or Arc amp of today. B)
The year is unknown to me. I got lucky and founf one on Ebay after searching forever. I also picked up a 4 channel and a 100HC that was in need of repair. however, the HC is damaged beyond repair, so I am getting rid of this one to go all new stuff. The amp is sold by the way.
