okay i just baught a cd player,two 10's and a Pioneer GM-X302 amp well i have a 95 chevy do i cutt my dash too put my new cd player in or what yall are experts ima noob and where should i place my speakers? and how would i runn the wire to the cd player if i put in thos 10's and that amp in the back?? plz help anyone add a opinion anything will make anything better
first off, don't do any cutting... Please give us the full information of your car. year? model? all stock? did you just buy subs and an amp? what kind of CD player did you get?
You should not have to cut anything. Please remove the word cut from your vocabulary. Also, do not handle any tools that can cut without supervision. Order the correct install kit for your truck, also order the correct wiring harness. Your truck will also require an antenna adapter. The subs will go under the back seat. Find a downfire box. ProBox is a little pricey, but well worth the money. They are very well built boxes. The amp is a little small. It would be good for highs but not for subs. Look for an amp thats atleast 300 watts or more RMS. We want RMS power rating, all other ratings are worthless. RMS. But keep in mind that you have very little room for an amp in your truck. Make sure the amp is small enough to mount it where you want it.
well i just baught it,and i just want bass? not no twitters or anything the cd player is DUAL?the 10's are pioneers and my amp is more than 300? its a 302...i was gonna build a box my self there no hard at all and i have some room under my seats for 2 10's and the amp i will place by the 4 wheel drive shift? thanks for helpin keep in touch so i can get this done
my mp3 cd player <a href="http://s294.photobucket.com/albums/mm95/kaoss2/?action=view¤t=09133311.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm95/kaoss2/09133311.jpg" border="0" alt="Photobucket"></a> this is my dash were i wanna put that cd player!! <a href="http://s294.photobucket.com/albums/mm95/kaoss2/?action=view¤t=09133258.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm95/kaoss2/09133258.jpg" border="0" alt="Photobucket"></a>
Your amp is no where near 300 watts. Its rated at 30 watts RMS X 2. Its bridged mono output will be less than 150 watts RMS. You need more amp
I still didn't get the year and make of your car. there are install kits for the stereo that you can buy so it will be a perfect fit but i need to know the make, model and year of your ride dude. Let's get the harness and stereo install kit out of the way first then we'll work on your subs and amp.
okay to get your stereo properly installed you'll need the following. they come with directions so it will be a snap to install. http://www.crutchfield.com/p_120993002/In-dash-Receiver-Kit.html?tp=3121 http://www.crutchfield.com/p_120701858/Receiver-Wire-Harness.html?tp=2977
what ranger told you earlier is right on target. He's surely right, he's been an installer for a LOOOOOONG time (but now a math teacher). You can pick up at 300watt amp for pretty cheap.. did you just buy your amp or have you had it for a while now?
