I was looking for a cheaper alternative to Dynamat. I have a gut feeling that 1/2 the price of it is for the name. I saw another forum post about this material from Mcmaster that is equivalent, but the price seems too good to be true. http://www.mcmaster.com/#polymeric-mastic-sheets/=8nx57q 9709T39 Sound and Vibration Damping Sheet EVA Mastic, .079" Thick, 32" X 54" In stock at $16.62 Each Has anyone ever used this? If not, what did you use instead of Dynamat?
If its got weight..got density....got a way to stick yo a resonant surface..it will work. period. The transferance of acoustic energy to heat is the primary method of this stuff. So even slapping on a coat of roofing tar to your door panels will work.....and done in enough layers would probably work better and cheaper than dynomat... ya ....really.....
