Amplifier to match 2xPionneer TS-W2501D4
Discussion in 'General Car Audio Discussions' started by Bonesy, Jul 14, 2009.
  1. Bonesy
    Bonesy New Member
    I am trying to find an amplifier to match with two Pionneer TS-W2501D4s
    The subs are Dual Voice Coil at 4 Ohms; Nominal Power Handling 800 Watts, MAX. 2500 Watts.
    I am intending to wire all 4 Voice Coils in Parallel to load the amp at 1 Ohm, or wire 2 Voice Coils in Serial and then in parallel with the other 2 coils to load the amp at 1.6 Ohms.
    I thought I had a Amplifier that would maximize these speakers, but as it turns out is only 225W x 1ch @ 4ohm bridge.
    So I am looking for an amp, please provide suggestions... I was thinking a Mono Class D. What would I need power wise, 1600W Nominal at 1 ohm? Would it be ridiculous to have 2xAmps at 800W Nominal?
    Thanks for any guidance.
  2. liftedranger08
    liftedranger08 Full Member
    A hifonics 1610d amp would be good. Its 1600 watts at 1 ohm.
  3. Kvo_8
    Kvo_8 Full Member
    x2, its affordable and beats pretty nice
  4. liftedranger08
    I used to have a hifonics 1200d and it was awesome for the price so im sure the 1610 is good.
  5. Kvo_8
    Kvo_8 Full Member
    lmao i had a similar model, i had the 1206d, ended up selling it to my brother. hes still running it in his car wired at 1ohm on a 12" type r
