Ampilfier remote
Discussion in 'Car Stereo Amplifiers' started by jcurry05, Aug 1, 2006.
  1. jcurry05
    jcurry05 Full Member
    Hey, I just bought an amplifier remote that plugs directly into the rca cable. Does anyone Know what I should place the gain on so there aren't any problems? thanks
  2. aznboi3644
    How the hell does it plud directly into the rca cable???
    Are you talking about a signal booster doo-dad???
  3. jcurry05
    It might be. I bought it off e-bay. It works though. does the rca cables have anything to do with the gain.
  4. aznboi3644
    No...rca cables just transfer the signal...post the model number, specs, and/or picture of this "amplifier remote".
  5. TheViking
    yes please, define "amplifier remote" ??????????????
  6. fstrfvo
    fstrfvo Full Member
    Might he be talking about a line driver???
  7. TheViking
    AH HA!
    Its just a passive volume control, thats it. It WILL NOT provide any gain to the signal. Set your amp gains properly and use this device to lower the volume of whatever channel you want whnever you want. it will not hurt your system.....
  8. jcurry05
    Thanks, The Viking. I appriciate the help.
  9. Hautewheeler
    Hautewheeler Full Member
    yup, this is basically an inline resistor that changes an input signal from full, and converts it down in stages to everything below full. These do not add any "power" to the system, just allows you to turn down the amp (by turning down the signal to the amp) without having to turn down the volume of the host signal. They work wonderfully, but be sure that you don't have the gain set at full (before the "remote") incase you do experience a failure from that unit.. it doesn't look like a very sturdy example.
