Amp suggestion!
Discussion in 'Car Stereo Amplifiers' started by 3rdgenmaxi, Nov 5, 2009.
  1. 3rdgenmaxi
    3rdgenmaxi New Member
    hey so i currently have 2 re se 12's dual 2 ohm subs but i need some advice on what amp to get to pust them because they have to be wired to 2 or .5 ohms? id like to stay under 250...
    hmmmm lets see.... for that budget id say power acoustik comes to mind.
    audiopipe too. the big one. the 3000d. it has some good power output for a cheap amp, as does the PA amp.
  3. pedro quiroga
  4. 3rdgenmaxi
    okay i was looking at the audioque but it only does like 850 at 2 ohms and i have 2 dual 2 ohm subs so i can only wire it to 2 or .5 ohms right? will the 1200d do more than rated?
  5. jonnyv713
    i have heard it will do more.
  6. 3rdgenmaxi
    kool kool thanks man bc i had two 1000 watt kenwood amps awile ago but got rid of them bc i had to wire each sub to 4 ohms and the amp only put out 300 watts at 4 ohms (probably less being a kenwood) so i sold both of those to help fund 1 large amp
  7. pedro quiroga
    ok then the huge power acoustik amp. the 5500d. its like in the 2k range at 2 ohms.
