Amp recommendation for 2 Jl 12w3v3-2 Subs
Discussion in 'Car Stereo Amplifiers' started by mino922, Oct 4, 2010.
  1. mino922
    mino922 New Member
    Hi I was wondering if someone could recommend an amplifier if I am going to be running 2 Jl audio 12w3v3-2 subwoofers?
  2. TheViking
    yep, buy the most powerful quality amp you can afford.....seriously
    no flea market crap. get a good amp from a reputable dealer and get the most power you can afford...
  3. fstrfvo
    fstrfvo Full Member
    take a look at the diamond audio D3 1000.1, very clean and powerful, will push those subs very hard.
  4. TE5LA
    TE5LA Guest
    You need to make sure the amp can operate at 1 Ohm loads. You might also check out the Memphis Audio MC1100.1.
