amp problem (help)
Discussion in 'Car Stereo Amplifiers' started by dwayne krause, Jul 22, 2008.
  1. dwayne krause
    dwayne krause New Member
    Hello. I am new here. I am running a Kenwood Exolon head unit and when I hook the input cable from the sub out to the sub amp the speakers "flutter" or move back and fourth very quikly. But when I hook the same amp to the rear output they work fine. Anybody ever had this problem? Any help would be greatly appreciated.
  2. G3n3R@1
    G3n3R@1 Full Member
    can we get these threads moved/deleted? :mad:
  3. dwayne krause
    Did I put it in the wrong place or are we not supposed to ask questions on this forum?????????
  4. cccullen
    i don't think G3 meant that. we had some answers for you but they aren't on the thread anymore. I wonder what happened.
  5. cccullen
    it sounds like there may be a problem with your sub preout.
  6. G3n3R@1
    G3n3R@1 Full Member
    basically there was just a double thread, i should've posted it in the one he has going in the new member forum. no need for two of em. plus i removed my answer because i realized he said his amp works off the rear output so it has to be based on the rca wire or headunit. maybe the ground for the headunit is interferring with amp on that specific output?? haha i dunno maybe run a new ground for your headunit.
  7. dwayne krause
    That was it. Ran a new ground and works fine now. Thanks for ya'lls help.
  8. justacarguy
    justacarguy New Member
    This sounds like an open ground trace on the sub pre-outs. Usually caused by poor amplifier grounding.
  9. jonnyv713
    old thread buddy...
  10. justacarguy
    I know, just thought it might help the next guy. Thanks tho.
