amp noise
Discussion in 'Car Stereo Amplifiers' started by philmetz, Sep 28, 2006.
  1. philmetz
    philmetz New Member
    i connected my deck to amp. Theres a cable from my deck sayin: "AMP REM..." i connected from there to my amp where it says "remote on off". Now wen i play music it makes a noise like a disturbance or so, its like a whistling noise. now wen i disconnected that remote on off wire the noise goes away but my sub connected to the amp doesnt work anymore???? WHY
    WHAT CAN I DO TO MAKE THE SUB WORK BUT GET RID OF THE NOISES??
    the remote wire is the on/off switch from the radio to the amp.that is why it is not working.the remote is most likly not the cause of the noise. it could be a bad ground to the amp,bad rcas(or damaged),or just a crappy amp.what kind of amp is it,and is this your first install?check all your connections maybe something came loose or is grounding out on somthing(pinched wire).
  3. aznboi3644
